i am thinking about a turbo or a supercharger for my 1.6 zetec se engine to increase its modest 100bhp.
rotrex do a supercharge kit but its alot of cash
any idea what the cost might be to fit one or the other???
if anyone has pic's of one fitted or a list of the parts needed to do the job that would be ace.
it only has to be a small turbo or SC as im sticking with the standard internals
many thanks
Have you seen Paul Collingwoods 1.6 mods? 194bhp without turbo or SC... Probably just as expensive though!
The mods to my 1.6zetec are
ported cylinder head
high lift cams
pocketed pistons
steel rods
active technology throttle bodies
larger injectors
and mapping at emerald rolling road
I built the engine my self so yes I am pleased with 194 bhp
thinking of fitting forged piston , bigger valves and new exhaust when I have the spare cash
i will be intrested in this also,always wanted to supercharge a car.
194bhp with no turbo or sc is very good work, but like you said very costly
my budget is low for this so it does need to be a locost special
the plan is to make the exhaust system and any mounts needed my self to save £££ and spend it on the ecu which i think is going to be the most
expensive part.
I've got the teeny 1.25 Zetec in my Mojo (75BHP) and I think I'll upgrade to the 1.6 at some point soon. You can always do with a bit more
power!
I agree that Pauls mods are probably expensive, and I'd love to see what Turbo/SC mods this thread shows up.
Here's a supercharged 1600 Zetec-S project... Uses an Eaton M45.
Linky
1600cc all alloy 16v Zetec SE
Eaton M45 Supercharger
Behr Chargecooler (Watercooled inlet charge)
DTA S60 pro ECU
Probably expensive too! <sigh>
And here's a fairly good article regariding the Zetec-S/SE tuning:
Linky
there is some great pic's of the engine with the supercharger and charge cooler fitted
interesting how the article on zetec se tuning says not to go down the forced induction route and to just go N/A when people seem to be having sucsess
with supercharging.
It might be worth looking at using something like the carger from a mini cooper s? or from a golf g60? would be much cheaper to buy than a new one i
would have thought, management wise look at something like a greddy emanage, then look at someone like Ryan G from 2bar tuning to fit and map it,
he's a mate of mine so ask if you need some details.
small intercooler, bigger injectors and a decent walbro fuel pump and your away.
the only hard bit would be mounting the s/c and fitting the belt/pulley system.
why not just fit a 2l zetec gota be cheaper and easier with after market ecu and the trimmings would work out better that a forced 1.6?
however, if still think supercharger is the way, for there are some nice aspects to doing it i got to admit. how about a used super charger of a new
mini cooper, i think there had cheap on ebay coupled to a cheap charge cooler and adequate ecu would be fairly straight forward
my Zetec S fiesta with 1.6 engine was turbo'd by van aaken developments however there not trading anymore, my car was used for the development, resulting in a blown turbo after 3 weeks, but once repaired, my 103 hp went up to 155 and loads more torque was brilliant on the motorway in 5th would have been ace if i'd removed the power limiter from 1st gear
what was the cost of the turbo kit rick? im temped by a turbo as you can pick up small turbos like a ct26 very cheap and won't have the fuss of
mounting it straight for a belt like a SC, i looked at the eaton 45's like the cooper s one, they are fairly cheap but much more than a cheap
turbo!
can you remember what boost the turbo was putting out? im sure i remember 0.3bar from somewhere
my biggest worry is the ecu and the cost, i don't understand ecu's
there are a few 2.5lt turbo st engine + gearbox's on ebay, start at £750... now thats very tempting
I supercharged my 106 GTi trackday car. The results were pretty good, it went from 125 to 199 bhp atw but I wouldn't call it a cheap conversion,
it needed forged pistons to work properly, intercooler, management etc.
Proper little toy on track but doesn't get used so much now I've got my Westfield
i run a se engine, in N/A form, stock bottom end, bodies cams headwork 175bhp, revs to 8k
t2.5 and a decompression plate with a 5th injector...tis as simple as that...
it is...i have done it....
no messing with exhaust to fit a turbo?, no sorting the fuelling out? the pipework for the setup?
this was my first attempt in 2001...
it was on an escort cabriolet 1800si
it had a t3 turbo, 2mm decompresion plate and a 5th injector...
done on a budget of £500....and i was only 21 at the time....was my first big project...
i made the manifold adaptor and just reused bits from an rs turbo.....5th injector is from a cosworth and is plummed in from the end of the fuel rail
where you test the fuel preasure...it is controlled by a preasure switch.....
when im bored with the pinto i will do a 2.0l one.....have learnt a lot since then so will make it better...
fair enough on that engine as the parts are there and fit and alot of people do zetec turbo's, there are very little turboed zetec se engines or parts for that matter, ford are releasing a turbo version of it soon though so that should change things for the better
i must appologise, i didnt read the se bit....doh!!!......im sure MAD devolpments did a conversion for the se...i know they used to do a conversion for the 1.7 puma and the ford ka....im sure it would not be too difficult to do....
if anyone is thinking of turbo charging one and wants some help i would be interested in lending a hand....
I'd go with the supercharger myself.
Yep its all do-able on the cheap but prob won't be very effective.
Obviously the pic above is zetec not zetec SE, different kettles of fish entirely!
Also very different job fitting it in a locost!
If money were less of an issue then either fit a duratec, or if you want to stick with the SE (and they are light and nice engines) then a small
rotrex blower would be perfect, just not cheap!
hi guys if you can hang on till mid 2010 then fords will be putting out a 1.6 turbo sigma motor will 185bhp as std. so to be followed with a 230bhp
one..
cheers terry
Originally posted by terryroberts
hi guys if you can hang on till mid 2010 then fords will be putting out a 1.6 turbo sigma motor will 185bhp as std. so to be followed with a 230bhp one..
cheers terry
Hi - I'm new to this forum - planning to build a Sylva J15 - interested in tuning a zetec SE - would like to get hold of Paul Collingwoods'
spec for the parts he used.
Any help much appreciated - Cheers
Originally posted by joe90
Hi - I'm new to this forum - planning to build a Sylva J15 - interested in tuning a zetec SE - would like to get hold of Paul Collingwoods' spec for the parts he used.
This is a graph of the big valve inlet port flow of the SE development head, below it to the right is the percentages increase in flow, i have now got
to start on the exhaust.
neil
[Edited on 28/2/10 by ncoll]
wow thats impressive!
just going back to the emerald ecu, is it a plug and play job?...
Can i just ditch my ecu, plug in the emerald with standard injectors, inlet manifold etc and have myself 8k RPM and a few extra horses... and then
rolling road it when i add new cams, inlet etc or is it not as simple as that?
i might be able to live without a turbo if i can have an 8k rpm engine
Can i just ditch my ecu, plug in the emerald with standard injectors, inlet manifold etc and have myself 8k RPM and a few extra horses... and then rolling road it when i add new cams, inlet etc or is it not as simple as that?
i might be able to live without a turbo if i can have an 8k rpm engine![]()
Linky
DTA S60 pro ECU
HOLY THREAD RESURRECTION BATMAN!
2yrs 2 months. gotta be a record......
The power of google you see![]()
Originally posted by beaver34
allways looked at your thread wandering how it turned out!
Since I last replied (two years ago!) I've supercharged my Westfield, these are the before and after dyno results -
Cool,
I'll check the thread out
This is mine itbs and turbo zetec se, on engine dyno next week
Nice !!
Have you got any more pics of the Jenvey Plenum ?
Nice !!
Nice !!
Yeah loads, any spesific bits of it?
I am sure Paul wouldn't mind me telling you the spec of his engine, the cylinder head is one of my flow benched developed standard valve size fast road heads. The cams a rally spec, standard pistons but with pockets in, steel rods. It has 38 mil throttle bodies, exhaust manifold is standard road car riot. The car develops 192 bhp at 7900rpm. I am at present developing a big valve head for this years engine. I will put a graph on of the big valve flow and percentage increases later. The reason it is a fast road head is that this was all it was going to be used for in the beginning. Then it became a trackday car, then a race car, but still with the drivability of a road car.
neil collingwood
