I've decided to stick a Duratec into the Quantum pending the V8 being ready.
So, Fiesta ST150 lump arrived today and I've stripped it back to the 'bare essentials' (and boy does my back know all about it
Can anyone give me a list of wiring-loom-end sensors that would be handy to keep? Just want to make sure that I'm not overlooking anything I may
come to regret!
Coolant temp sensor, fitted to back of head in water outlet
Crank position sensor on drivers side, front of block.
Knock sensor - on passenger side of block, middle top.
Oil pressure switch, on oil filter housing.
Coil connector from loom.
Inlet temp sensor from the inlet manifold if its fitted with one.
Other than that you dont really need anything else.
Perfect! Thanks david!
Got to be a thumbs up for the Xtreme + duratec combo
