Anyone know the bellhousing pattern on the little 1.25 zetec?
Will a type 9 bolt up to this engine?
Ta,
You upgrading
See ya tomorrow btw
Rich
it bolts straight onto the ford IB5 gearbox. so is the same fitment as the 1.4 and 1.6 zetec SE. if thats any help...
May be of interest...
Link
Ed.
Just thinking of dropping one into my Jago later on. Just gathering info atm.
Thanks,
See you there Rich, weather looks good
Cracking little engine... I run one in my Mojo - see my website for more info : Link
The 1.25 puts out 70-75bhp which is not huge, but it revs really easily and is nice and light so performance can still be quite rewarding!
Here's a dyno report for the 1.25 : link
Ed.
Just what I was thinking Ed, looks cracking install there. Are you using the Ford management or something else?
I used to have that engine in my fiesta. Cracking little motor
I'm running the standard Ford EEC-V ECU at the moment, but I've just bought a 1600 SE lump and now I'm wondering about an ECU upgrade.
Omex, Emerald, Megasquirt - hmmm....
I've started off with the 1.25 because it was in my donor car so I reused as much as possible to keep costs down and get me on the road as soon
as possible. Now I'm a bit more used to rear wheel drive I've decided that a bit more power wouldn't go amiss. Also, this engine has
done just over 100K miles and I'm not sure how much longer it'll last when I start doing some trackdays. They're pretty bulletproof
really and it runs as smooth as a nut but I need a winter project!
Ed.
I'm just about to start building a mates car which has the 1.6 Zetec SE engine in it, he already has the Emerald ECU.
i also run a se engine, with a shawspeed bellhousing on it, if you need anypics let me know
