I've got myself a stainless flange, but I was looking at the manifold that came with the ST150 engine and it looks like it's a fairly decent
design (equal length primaries) and may be adaptable (mild steel)!
My thoughts were to cut it at the first collector flange and then weld in a suitable diameter down tube.
Only thing is - am I likely to lose a whole lot of torque by going so unrestricted so early on a manifold with such short primaries???
Image deleted by owner
Pic looking inside the collector...
[Edited on 2/11/09 by scootz]
Got a pinto manifold?
If so chop the plate off the std duratec one and the pinto one will line up within a couple of mm anyway
Just need to tweak the pipes to line them up properly.
Edit to say the primaries on the std manifold are waaaaaay too short for a decent performance engine.
[Edited on 2/11/09 by flak monkey]
Thank you Sir!
