Pic Request! Securing MK fuel tanks?
Toprivetguns - 2/11/09 at 08:06 PM
Hi guys!
Just curious about methods of attaching fuel tanks your cars. I thought MK would of welded me some brackets on the sides, however no luck there. Any pictures would be greatly appreciated !
[Edited on 2/11/09 by Toprivetguns]
eznfrank - 2/11/09 at 08:35 PM
When I asked MK they told me they now just use sikaflex and nothing else. if you're not comfy doing that then a couple of ali straps with rubber between them and tank
Hammerhead - 2/11/09 at 08:36 PM
I welded nuts to the bottom of mine and bolted from beneath
mackei23b - 2/11/09 at 08:37 PM
With ali straps, riveted to the bottom chassis rail. Also had rubber / foam between straps and tank.
I've seen sikaflex used and it's strong, but was not so keen on this method!
dhutch - 2/11/09 at 08:47 PM
Very tidy looking straps. Did you make them yourself?
Toprivetguns - 2/11/09 at 09:22 PM
Im a terrible! I need pictures to visualize everything. Thanks again chaps. No doubt you'll hear from me again. lol
mackei23b - 2/11/09 at 09:48 PM
Thank you, yes home made, I must of had too much time on my hands!
Ian
sebastiaan - 3/11/09 at 07:12 AM
I used one of these kits:
strap kit
Works a treat for little outlay. Proper locost if you can get these from a scrappy, too!
Edit: IF you're lazy, see ebay item 360196791015 ;-)
[Edited on 3/11/09 by sebastiaan]
