ok been changin the dizzy tonight, on the pinto (2.0)
i noticed the cam belt seems quite loose, and when you turn the engine over there is a tiny delay (is it called an engineers delay on lathes etc???
its like that)
how tight should these be, can the tensioner be adjusted ordo they wear out?
tdc, im pretty sure i have found the marks, jacko has been really help full but does anyone have any pics of the markers, just to double check,
when setting up the dizzy, am i right in thinking that aslong as tdc is set on one firing point, it doesnt matter which one (im not talking about ht
leads or orders, yet)
and finaly, is the firing order 1,3,4,2
cheers chaps!
No sure about the other bits, but 1,3,4,2sounds right.
I would suggest not connecting it up 3,4,2,1 i.e. out by one post all the way round as it produces some interesting noises and flames
if you haven't got a tension gauge..... then you should be able to twist the belt 1/4 of a turn on the longest span
[Edited on 19/11/09 by mcerd1]
The Pinto has a belt tensioner, you need to slacken it's locking bolt & the pivot bolt (splined head) slightly so the tensioner can move, the
carefully rotate the engine from the crankshaft pulley 2 full rotations clockwise, as you finish the 2nd rotation be careful that the crank
doesn't "rock back" if a piston is under compression, then retighten the locking bolt followed by the pivot bolt. The tension will then
be set correctly.
[Edited on 19/11/09 by russbost]
Originally posted by russbost
The Pinto has a belt tensioner, you need to slacken it's locking bolt & the pivot bolt (splined head) slightly so the tensioner can move, the carefully rotate the engine from the crankshaft pulley 2 full rotations clockwise, as you finish the 2nd rotation be careful that the crank doesn't "rock back" if a piston is under compression, then retighten the locking bolt followed by the pivot bolt. The tension will then be set correctly.![]()
Stick a pencil down the no1 plug hole to check for TDC, turn engine slowly and watch pencil. You'll see it rock at TDC
