been offered a granada diff code says m , 2.0 dohc its not lsd ,are the codes gospel ,is this worth buying with view to sell,what is it worth?thanks phil 01254382963
If its a granada then its a 7 1/2 inch not a sierra 7 inch size...
was sure the 3.14 only came in a deisel, but could be wrong
My 7" 3.14 diff came out of a 2.3 V6 Mk1 Ghia.
HTH
Neil
Hi have a look in my photo archives there is a section on diffs with info
Jacko
7 1/2 " diff will fit in a Viento No problem.
However, It wont fit in much else, if it was a LSD then I would have it off you!
You will need the matching shafts etc.
Only problem then is the 5 stud hubs which can be changed to 4 stud ones. However, again you need the right ones.
Mr Green Giant knows all the ins and outs of this operation. Not difficult, but you do need the right combo of bits.
