Is it as important to let a supercharged engine cool down after a long run as you would if the engine was turbocharged.
-Ash
no, the turbine components do not get very hot and no where near turbo temps
If its a Rotrex it may be wise to idle the engine for a minute before switching off to allow the oil/traction fluid circulate and cool a little as the
fluid is not rated at a very high temp.
id say yes too, just to let the oil circulate and cool a touch
If it's an eaton type then I'd say it makes no difference, not sure on centrifugals.
it would appear you should do whatever you like
yes the cooper supercharger is eaton m45 I think
Isnt letting the turbocharged engines idle for a while before switching off, to give the turbo time to stop spinning and prevent the lose of engine
oil pressure mullering the turbo bearings?
With a supercharger the engine stops turning, and so does the supercharger.
Originally posted by Project7
Isnt letting the turbocharged engines idle for a while before switching off, to give the turbo time to stop spinning and prevent the lose of engine oil pressure mullering the turbo bearings?
You don't leave a turbo diesel engine running for a minute at the end of your journey do you? That doesn't seize all the time.
Most turbo chargers are also liquid cooled to remove this very problem. I.E. the engine coolant soaks up any heat, not the turbo. As a supercharger
isn't using exhaust gas at hundreds of degrees, its going to be fine.
Thanks Guys,
I thought i new the correctish answers, was just checking i had not missed an important point.
-- Ash
