Are the fasteners that hold the clutch pressure plate on a special grade? Or can I just use 12.9 cap heads?
It's been years since I've changed a clutch and I cant remember - just trying to pre-empt our fastener requirements for our xmas engine
change (gonna be hard getting anything over the holiday period).
Obviously under normal circumstances you'd re-use whats there, but our Duratec hasnt come with a flywheel.
Normally Ford used M8 x 12mm 1.25mm pitch Flanged Hex head Set screws grade 8.8 hex size was 10mm.
Might be hard to find M8 in 12mm length
Ebay item 150323633824 should be a suitable replacement.
Or these 350120990404
Remember use some Loctite
Thanks mate
8.8 - less than i thought.
