Anyone know the best place to source 20v gasket set for an engine strip and rebuild ? Not sure if they can be ordered through any Toyota dealer being an import engine.
I bought a gasket set from ebay for a 3sgte.
Apart from the cork sump gasket leaking, it has worked fine.
Darren
So all the gaskets fit ok with enough and the right holes in the head gasket, and does it come with bolts ? I will use sealant for the sump anyway.
Yep, they were good,exact fit, head was for a later version as i wanted a metal head gasket, done 1000 miles so far, head gasket has been fine.
Oil seals were good quality.
Darren
[Edited on 27/12/09 by turbodisplay]
I got a head gasket from Fensport (back in May) so that would be my first call. Excellent service as well.
You could also try BPJ Services, who build/modify 4AGE 16V and 20V variants.
LINKY
Pete
If I recall correctly, BPJ Services didn't stock the gaskets the last time I tried hence the call to Fensport and the shinney new TRD gasket.
They may have them now so this would be my second call.
Both companies offered excellent service as I have used them both several times in the past.
last resort?
silvertop 20v ebay
blacktop 20v ebay
whenever looking for 4age parts on ebay internationally search for 4ag* as the 4age is mostly referred to as 4ag
[Edited on 28/12/09 by Werner Van Loock]
toyotas never came with sump gaskets. they used grey sealer called ultragrey. but any good quality sealer will be good. toyota dealers can get the
majority of import parts. it helps if you know the model code and the 1st few digits of the chassis number. also helps if you got a good parts guy
behind the counter too as some cant be bothered.
Rob
Hi
I might be able to obtain a head gasket set Part No. 04112-16210 > see the following web page for info >
http://opc.mr2oc.com/online_parts_catalog/20v/gasketkit-overhaul-valvegri.gif
For about £100. Would you be interested
Rich
