k&n / pipercross filter what oil
martin1973 - 3/1/10 at 07:17 PM
what oil would any of u suggest for coating air filters with i know you can buy the proper stuff but whatelse can i use?
MakeEverything - 3/1/10 at 07:34 PM
I wouldnt.
Never have done, and never had any problems.
austin man - 3/1/10 at 07:45 PM
its around £12.50 from ebay you get a cleaner and an oil spray
Chippy - 3/1/10 at 11:22 PM
I had run out of the real stuff, and when I washed out the filter, I just used a drop of 3 in 1, not that I would recommend it, but it seemed to work OK. Cheers Ray
02GF74 - 4/1/10 at 12:02 PM
seem to recall thjis being discussed elsewhere and consensus was that the oil is a special waxy stuff specially made for the filters (or may be just K&N blurb to get you to buy their stuff).
for the few quid spent and the few times you need to re-oil the filters, it is not worth the risk in damaging the engine (not that I can see it would even without oil but .... )
I wouldn't bother with the cleaner - use petrol or paraffin poured from the inside of the filter to wash the muck out - tapping the filter helps dislodge the bigger particles.
Petrol will dry quicker, then re-oil with the red stuff and job done.
[Edited on 4/1/10 by 02GF74]
Angel Acevedo - 4/1/10 at 12:10 PM
Martin1973
Just looking at the affinity ATF fluid has to dust -just see how mucky a leaky auto trans gets, I would use ATF Fluid and reduce cleaning intervals just to make sure.
HTH.
AA
