splash plate between engine and gearbox?
rich201283 - 21/1/10 at 09:03 AM
Does anyone have a metal plate that sits beween the engine and gearbox on a type 9 to zetec engine? I would like to buy one.
stuart_g - 21/1/10 at 09:12 AM
I believe you can buy these from ford, although you normally have to still add bits to it to cover up the holes in the bell housing.
Why don't you make your own from a thin (1mm) sheet of aluminium or steel. If you stand your T9 on it and draw around the bell housing, then cut it out. You will then have to remove some of the middle so it will fit onto the back of the engine.
RAYLEE29 - 21/1/10 at 09:17 AM
Hi, I dont have one dont even know if theres one that fits possibly a cvh one but thats just a guess
you can make your own from a bit of 16 guage or get one thats not quite right and add to modify etc
by the way they are commonly called a sandwich plate and are more like a gasket so you dont have a cast bellhousing directly in contact with a soild cast block as this can cause the bellhousing to fracture
youll find that many cars with alloy bellhousings dont use one
hope this helps
Ray
rich201283 - 21/1/10 at 09:28 AM
I have the original one off the zetec so i may just try and modify that, As far as i remember the pinto one may fit
boggle - 21/1/10 at 10:35 AM
i need one to fit on my pinto to type 9..
if someone does a template or drawing i will cut a couple...
Daddylonglegs - 21/1/10 at 01:23 PM
Boggle, if it's any use to you and anyone else, I can use the one I have (engine/gearbox seprated at the moment) and make a card template of it and send that to you if you like?
JB
mad4x4 - 21/1/10 at 01:50 PM
FORD SEIRRA will fit
doddy - 21/1/10 at 04:05 PM
this is what you need
this is a picture i found on the net
i have used the pinto one i have just have to cut the middle out a bit and add a bit where the zetec starter would go
[Edited on 21/1/10 by doddy]
