Has any one got a drawing or measurements of a v6 type 9 gearbox bell housing. i'm looking the dimensions of where it bolts to the engine.
Where it bolts to the engine is the same as the normal Type 9 if that helps you widen your search at all.
James
i have a drawing of the spacer thats needed to turn it into a pinto one
have a spare spacer actually if thats what you want it for
dave
James
What do you need to know?
I have a V6 box in the garage, a V6 bellhousing with it and a V6 Type 9 with spacer and RS2000 bell housing in the car
The bell housing bolt pattern for the 4 cylinder fords is the same from the Crossflow to the Zetec. The V6 uses a different bellhousing bolt pattern
than the 4 cylinder engines but is the same pattern for all V6's from the Essex 3.0L to the Cologne 2.9L.
U2U Dave for a copy of the drawing
