What are the general rules on prop angles?
The outtput shaft of the gearbox is around 25mm lower than the diff, but is aligned lrft to righ. is this likely to be an issue?
Thanks,
as long as the gearbox output and diff input shafts/flanges are parallel then you should be fine
i think thats the general thing
[Edited on 23/1/10 by blakep82]
They must be parallel, that's very important. It's desirable to have an offset though as it distributes wear in the joints.
parallel and offset at the same time ??
how does that work?
surely either perfectly in line with no misalignment and the uj's are just there to take up movement in bushes etc, or its beneficial to have an
angle in each uj for even wear?
and if its with a small angle in each uj why would it matter if the were in the same plane, i,e, diff and output shafts parallell?
aitch
how does that work?
surely either perfectly in line with no misalignment and the uj's are just there to take up movement in bushes etc, or its beneficial to have an angle in each uj for even wear?
aitch![]()
Prop angles
Top shows a good installation, with shaftes parallel but offset. Middle is OK as well, but bottom is really bad and will cause bad vibration.
Basically, if a UJ is angled and the input speed is constant, the output speed will fluctuate during each revolution. By having an equal and opposite
angle at the other end of the prop you cancel this effect out. If making your own prop be careful how you fit the UJs as they have to be phased
correctly with respect to each other for this to work (90 deg out if I remember correctly).
If the shaft is perfectly straight, the same point on the UJ bearings will always be loaded. If you have an angle in the UJs then throughout each
rotation the bearings are constantly moving and spreading the wear over more of their surfaces.
[Edited on 23/1/10 by matt_claydon]
Why?
Sorry - That wasn't very clear. Why is it such an issue on cars that only cover a couple of k miles per year and are normally stripped and
checked every couple of weeks.
I have a 2 piece prop but the faces on the joints are not quite parallel (engine mounted on a slight angle). There is no noticeable vibration even
though my engine is solidly mounted.
[Edited on 23/1/10 by Richard Quinn]
If the bearings are in line the rollers stay static and wear a flat on them instead of rotating and evening out any wear. It will probably not matter too much in a low mileage situation like a kit car but it does happen.
This video has some good backgound info to understand how UJs operate.
http://www.youtube.com/watch?v=xgQgm3GwaFs
3:15 onwards specifically
Originally posted by Richard Quinn
Why?
Sorry - That wasn't very clear. Why is it such an issue on cars that only cover a couple of k miles per year and are normally stripped and checked every couple of weeks.
I have a 2 piece prop but the faces on the joints are not quite parallel (engine mounted on a slight angle). There is no noticeable vibration even though my engine is solidly mounted.
Possibly, but there are also a lot of cut & shut propshafts used on kits.
Don't get me wrong, I'm not saying that it doesn't matter but it's not ideal. There again, a lot of the things we do , use, make
fit etc are not ideal either.
good video BUT given the home made nature of our cars how close do we think we can get to parrallel. Especially cars that are already built and may be
out of line. I'm currently looking at mine for this very reason as I have a slight vibration ( could be from not using hubcentric wheel spacers
though)
How many mm over say 600 of parrallel length would be acceptable
i.e. in the car a vertical staight edge on the prop flange and the gearbox tailshaft face 300mm above and below the centreline of each.
So how far out would be acceptable???
If you have a live axle it will to some degree possibly rotate as it rises and falls
so again an imbalance.
If you need to rotate your axle to align it parralel the the shock mounts will also be rotated ( bolts running from front to rear) and hence a strain
on the bolts/bushes.
Wish I had really taken more care of this during the build
So what's the group collective on how far out is acceptable.??
Originally posted by matt_claydon
Prop angles
Basically, if a UJ is angled and the input speed is constant, the output speed will fluctuate during each revolution. By having an equal and opposite angle at the other end of the prop you cancel this effect out. If making your own prop be careful how you fit the UJs as they have to be phased correctly with respect to each other for this to work (90 deg out if I remember correctly).
If the shaft is perfectly straight, the same point on the UJ bearings will always be loaded. If you have an angle in the UJs then throughout each rotation the bearings are constantly moving and spreading the wear over more of their surfaces.
So we are also now saying ( from pic2) that the faces do not need to be parrallel as long as the 2 angle are the same??
YES or NO
You should find all the info you need here Linky
Btw flak monkey if you type propshaft angles into the search box you will find more info
[Edited on 23/1/10 by TGR-ECOSSE]
YES or NO
From memory best keep diff flange and gearbox flange parrell. The prop should be run at slight angle (keeping flanges parrell, both horizontally and
verticaly), the maxium angle is 1degree (I think It maybe 0.5)... A slight angle is required to work the UJ bearings slightly. The angle gives you
some idea on how accurately we should align the flanges up to (<0.1degree???) I did the best I could.
It is possible to run without the flanges parrell (can't remember the details) but this needs to bet set up carefully to use the correct angles.
I assume this is what the BEC two piece props are setup like?
Do your home work on this and don't assume we all know what we are talking about! The low-millage get out is not the answer with a prop, it may
let go with no warning, and consequences don't bear thinking about.
Dan
PS double check, don't assume my angles are correct (U2U if you want me to check my build notebook).
[Edited on 23/1/10 by Bluemoon]
Thanks for the replies guys. I have made sure the gearbox and diff are as parallel as I can make them.
When the pinto was installed the engine was at an angle to clear the nose and there wasnt any noticable vibration, though ibviously it was far from
perfect. The new install should be much better I hope.
Now I need to speak to Bailey Morris about shortening my existing prop by about 2.25"
My MK kit was also supplied with BEC-cradle. But the engine is also not parallel to the diff when I will install it and I'm also afraid this will
cause vibration.
Apparently (Linky Linky) if it is not possible to get the gearbox and diff parallel you can
compensate this with rotating one of the UJ's. The angle of rotating this UJ is defined by the "misalignment".
I think I will put my bike engine in the car with the supplied cradle and do some measurements which I will send to Bailey Morris. If they can
compensate this misalignment I will keep the cradle. If not, I will have to rebuild the cradle and engine supports.
