blacktop to type 9 problems
lewis - 31/1/10 at 06:28 PM
hi all im having some issues with the above, i have a 2.0l blacktop, a 1.8 zetec flywheel and clutch and a type 9 gearbox the problem i have is the splined hole in the middle of the clutch plate is to small to fit over the type 9 input shaft, this is the combination i have been told to use,my thoughts are is it a type 9 gearbox? its from a 1989 sierra sapphire and is 5 speed with the reverse top left so im 99.9% that it is so 2nd thought is it the right clutch? if the answer is no which is the correct clutch for me to use with a 1.8 zetec flywheel type 9 box and cct133 bearing?
many thanks a confused builder
ashg - 31/1/10 at 06:34 PM
i remember reading something which said you use the zetec clutch housing with a sierra clutch plate. dont take it as gospel because i have never done it and am going from memory of something i read ages ago
big_wasa - 31/1/10 at 06:36 PM
Wrong clutch plate. There where two fitted to the early zetecs depending on gearbox. The one you want is the 220mm 23 spline 1" center that was used with the mtx75 gearbox .
You have the smaller one
This should do it
[Edited on 31/1/10 by big_wasa]
lewis - 31/1/10 at 06:44 PM
wow that was quick! thanks for the info guys at least a easy fix! ill get one sorted for it
big_wasa - 31/1/10 at 06:49 PM
Ive got a clutch kit in the garage if you need a part number.
lewis - 31/1/10 at 06:51 PM
yes please mate that would be a big help
big_wasa - 31/1/10 at 08:57 PM
ferodo CTK 1014
