K series High Idle speed
matty h - 8/2/10 at 11:29 PM
I have a 1.8vvc 143bhp k series in my GTM Libra it seems to have a problem as it sometimes does not idle and will sit at 2500 rpm and today it was sat at 3500rmp.
It has a 48mm ali throttle body and I have checked the inlet manifold for leaks but did not have any.
Anyone got any suggestions.
Major Stare - 8/2/10 at 11:53 PM
If you get no answer on this forum, try this one....http://forums.mg-rover.org/
MikeRJ - 8/2/10 at 11:57 PM
You may need to clean and/or reset the idle valve.
steve m - 9/2/10 at 09:54 AM
i have the opposite, my k series idles from cold at about 800rpm
and untill the needle is 2/3 up the scale, it can be a real pain driving, as it stalls
(thats in my road car)
Hammerhead - 9/2/10 at 12:21 PM
throttle position sensor?
matty h - 9/2/10 at 08:35 PM
I have cleaned the idle control valve out will see tomorrow if it has worked otherwise may need to check the throttle position sensor how do I know this is working correctly.
britishtrident - 10/2/10 at 05:15 PM
Check the inlet manifold is tight on the head.
matty h - 11/2/10 at 05:41 PM
Cleaning idle control valve seems to of done the trick took more than the 20 mins stated on the link more like an hour.
