I am converting my Robin hood from a 2.0l Pinto to a 2.0l Zetec and want to use my Dellorto DHLA 40s
Will these carbs need rejetting?
Also what bhp would i be looking at using these?
What are they jetted for at the moment?? I know there is a specific model number for webers used on zetecs as they need more ptogression holes drilled.
hi zetec needs 5 progresion holes jetting will do till you get it set up
The carbs have the 5 progression holes and fitted is:-
32mm Chokes
150 Main
7772.10 Emulsion tubes
58 Idle(we think)
7481.3 Butterfly
How would the car run on these?
