non welded fuel tank fittings
MikeR - 5/3/10 at 12:55 PM
i know this has been discussed before, i've tried searching 4 or 5 times and i'm not using the right terms.
I'm after a fuel tank fitting that bolts in. I know i've read about them - you drill a hole, hold a thread one side and twizzel the fitting on the other - voila one fuel return.
Can anyone point me in the direction? I think they where aircraft based.
RichardK - 5/3/10 at 01:02 PM
Knew I'd bookmarked it! Down at the bottom! Linky
Rich
MikeR - 5/3/10 at 01:11 PM
Thats the sort of thing - not keen on it being just a push in fitting though. Has anyone else got any links?
scudderfish - 5/3/10 at 01:15 PM
I've got one of those, but I've not run any fuel through it yet. The way I see it, if it's safe to be fitted to aircraft, it's safe for us. You could always run a bead of sealant around it to be sure.
MikeR - 5/3/10 at 01:26 PM
for some reason, with no engineering background, it doesn't seem right.
We don't just push on hoses, we push them on and clip them.
wondering about something like this with a copper washer to crush and then a barb made to fit into it.
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=3691564
BenB - 5/3/10 at 01:39 PM
Otherwise you can get tank fittings for cold water tanks that fit from one side only. Cost about £15 from BES (amongst others). You'ld then need a 15mm to 8mm (or 10mm depending on your preference) adaptor.
MikeR - 5/3/10 at 01:41 PM
think i may have just found what i'm looking for .... now unsure whether to go for it or not,
http://cgi.ebay.co.uk/NEW-fuel-vent-through-hull-fitting-for-in-board-tanks_W0QQitemZ400066466978QQcmdZViewItemQQptZUK_CarsParts_Vehicles_BoatEquipmen t_Accessories_SM?hash=item5d25d1d4a2
i'll look up tank fittings now.
BenB - 5/3/10 at 01:42 PM
http://www.bes.co.uk/products/103.asp
here we go. half way down.
access from the outside only required.
RichardK - 5/3/10 at 02:05 PM
That boat one look good...
big_wasa - 5/3/10 at 04:53 PM
I think I am just going to weld a barb into the sender plate.
I was looking at one for a tractor and thats how it was done.
MikeRJ - 5/3/10 at 07:55 PM
I wouldn't use that with the gauze in it, it will likely be quite restrictive for the volume of fuel that goes through a return pipe considering this is supposed to be an air vent.
Have you considered fitting a return into the filler neck of the tank (if possible)?
MikeR - 5/3/10 at 08:41 PM
Still have the same problem - the steel is 0.5mm thick hence looking for a non welded solution.
Got home, put the tank in (its an old army surplus tank that is probably a land rover second fuel tank - under seat) and ......
IT DOESN'T BLOOMING WELL FIT!!!!!!
Need to have a think over the weekend what i'm going to do. May just get a couple of fittings, turn it on its side and use it like that for IVA, tempted to try and fit the MGF fuel sender but that means i need a 3 or 4mm 15cm round plate welding to it somehow.
one day i'll learn to either make everything myself or just pay someone.
hicost blade - 6/3/10 at 05:25 PM
http://www.merlinmotorsport.co.uk/p10759/SELF-SEALING-TEE-WITH-8mm-PUSH-ON/product_info.html
Comes with a nytrile (fuel resistant) O ring and in loads of different sizes......
[Edited on 6/3/10 by hicost blade]
MikeR - 6/3/10 at 05:47 PM
oooh, lots of people do those if you search on the product code (although all the same price - wonder who supplies them originally).
Ah, just read up - seems they're designed for water and air take off. Doesn't mention fuel anywhere - nervous with the rubber ring that fuel will affect it and i'll be left without a seal.
[Edited on 6/3/10 by MikeR]
hicost blade - 6/3/10 at 07:26 PM
They are designed for all sorts of uses and have been used very successfully for fuel returns in the past with no problems whatsoever; nytrile (the o ring material) is in fact the material black fuel hose is made from....
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260481808672
