I'm trying to bolt a Mazda MX5 (NB) gearbox to my little 1.4 k-series engine.
The smallest Mazda friction plate to fit that gearbox is 200mm in diameter, the pressure plate on my engine is only 190mm wide.
After doing some research I found out that the 1.4 and 1.6 use the same flywheel, but the 1.6 has a 200mm clutch. So my question is: Would a 1.6
(200mm) pressure plate fit my 1.4 (190mm) flywheel? I can't really find it online, and after examining the flywheel I can't see where
that extra 10mm should go, both flywheels are the same though? Does that include the pins/holes for the clutch?
Another question; is there a store/place where I can buy just the pressure plate? Everybody seems to sell the whole kit, of which I cant use the
friction plate and release bearing?
Thanks!
[Edited on 5/3/10 by rost]
The bigger clutch will fit your flywheel ,the edge around the pressure plate is narrower on the 200mm thats were the extra 10mm comes from .
You must have a very early 1.4 engine, they switched to using 200 mm clutches over 15 years ago.
The clutch pressure plates changed at the same time.
[Edited on 6/3/10 by britishtrident]
