I definitely need much more cooling power in my raw striker due to the new engine.
can you suggest me where (online) I can find thick alloy radiators at good price?
thanks a lot
ALLOY RACING FABS MAKE 1 OFF JOBYS
pro alloy??
what size radiator?
Originally posted by 02GF74
what size radiator?
you can get a brand new VW polo ali radiator from northern radiators for about £30. popular choice on here. don't know what you've already got right enough.
And just as importantly get the airflow out.
Darren
Usual advice re rads is
"do you really need a bigger rad or do you need to improve airflow through the capious open nosecone of a 7?"
Sevens have a ridiclous amount of air flowing into the nosecone. Only problem is most of it goes round the rad. Channel it through the rad and job's a good 'un unless you're running crazy Bhp....
The air goes into the nosecone just fine, but if there is a gap around the radiator most of it will just go round (path of least resistance).
As said you also need to let it out again after it's done it's job.
