megajolt trigger wheel...
boggle - 30/3/10 at 10:32 AM
just looking at my megajolt triiger wheel....
does anyone know what bore size i need for a pinto and is there a keyway needed??
cheers
barry
Hugh_ - 30/3/10 at 10:59 AM
It's a year or so since I fitted mine, but from memory no keyway and I'd guess at M12, maybe M14.
boggle - 30/3/10 at 11:06 AM
thanks
will cut one of each...
boggle - 30/3/10 at 12:15 PM
another stupid question...
2mm steel????
cd.thomson - 30/3/10 at 12:19 PM
more like 5mm, you dont want the teeth vibrating at all.
blakep82 - 30/3/10 at 12:50 PM
5mm at least. 2mm will be too wobbly, and too thin to give you a decent signal
better if you can cover the whole end of the sensor
[Edited on 30/3/10 by blakep82]
boggle - 30/3/10 at 01:34 PM
well i can go up to 300mm......
Miks15 - 30/3/10 at 01:50 PM
might be a bit overkill, 250 should stop the wobble
Thinking about it - 30/3/10 at 02:01 PM
That will double up as a flywheel
blakep82 - 30/3/10 at 02:35 PM
mines 5mm i think. works well
well, as far as i can tell, considering my wirings not done, and the sensor wasn't lined up properly
boggle - 30/3/10 at 02:43 PM
does it have to be mild steel??? not ali??
is it because the sensor works on a magnetic field???
blakep82 - 30/3/10 at 02:59 PM
must be steel. ali won't work. the inside of the sensor is a little magnet
