Not sure if anyone does it but Weve been having problems with the Zetec getting airlocks so have come op with the idea of using tyre valves in the ends of pipe which we have blocked of. Works a treat and cost nowt so definitely locost
ah, a very clever idea
Renault use tyre valve caps as cooling system bleeds. Just the plastic cap, no valve.
So do peugeot, citreon, some fiats.....
Good idea.
rover use just the cap over a small hole.
just go to your local Tyre supplier they have hundred which are of no use to them or ask to keep the ones they cut off when you have new tyres fitted. We a fitted two to a zetec on to the top of the rad and one on the top of the Stat Housing
how do you fit them in? clamped into the rubber hose?
just a jubilee clip onto the hose, the valve is slightly flared so the clip will prevent it from being forced out.Just run it up to temp and depress
the valve, a quick burst of air then water "et voilla".
Try to ensure you place them at a high point though
Good idea for bleeding on intial set up, but a properly set up expansion tank/bottle and pipework will continue to remove air from the system
