Crossflow Sump Gasket
DavidM - 10/4/10 at 09:11 PM
Hi,
I've removed my sump to make a permanent repair after damaging it last year. When removed the sump had the standard cork gasket but this was coated both sides with gasket sealant. When I replace the sump, should I use gasket sealant or just the new cork gasket?
rusty nuts - 11/4/10 at 08:10 AM
Ditch the cork gasket and get the better type from Burtons . Cork always tends to leak my Burtons item has been used at least three times with no signs of leaking.
DavidM - 11/4/10 at 11:54 AM
Thanks Rusty, is that the grey one listed as competition?
rusty nuts - 11/4/10 at 02:19 PM
Yes , it's worth every penny. I just give it a light coat of Hylomar and haven't had any leaks at all
02GF74 - 11/4/10 at 04:03 PM
even with a vork gasket, you should not need sealant other than to act as a bit of glue to hold it in place before you bolt on the sump.
need to check if mine leaks or not.
