Did or rather tried to do our first sprint of the year today but had a real problem with the car.
After running a sweet as anything since we first hooked everything up we appear to now have a massive overfuelling problem (this is on Facet fuel
pump/Filter King and Fireblade carbs on a 1.8 Zetec.
It got so bad at one point you could see petrol sloshing about inside the cylinders if you took the plugs out ( I cleverly cleared that by
disconnecting the fuel pump, taking all the plugs out and cranking it, never seen a quadruple petrol fountain before and for a while I was the most
flammable man in Norfolk, I was drenched in the stuff).
We now seem to be able to get it running but it seems to be incredibly difficult to balance the Filter King between fuel starvation and a stupid
amount of overfuelling, a quarter turn of the adjuster screw seems to go from one to the other.
Bike fuel pump the answer or is it actually possible to get the current setup running properly and reliably.
[Edited on 18/4/10 by norfolkluego]
I would change your engine oil.
Bike pump or I would recomend a Huco pump sold by webcon for webers.
1.4psi and 120l/h
i would just go to a bike pump, no problem with pressure thenone less thing to go wrong. by the way where did you do the sprint?
Definitely go with a bike fuel pump.
Logic says a blade one to match your carbs.
Sling the Filter king and facet.
You'll get more for them on ebay than the bike pump will cost you.
[Edited on 18/4/10 by zilspeed]
Quick additional Q for all the bike carb genius'; Would the Filter King and Fact pump overwhelm the carbs, so not only are they flooding, but
pushing way to much fuel in the chambers?
I thought this was down to the jets, so if jets are correct, them carbs would flood but the engine would be receving correct fuel?
TBH i don't know enough about carbs, but i'm learning now.....
