Zetec
jeffw - 25/4/10 at 10:26 AM
Right, after the demise of the Silvertop yesterday I have to choose a replacement. The car is/was running Jenvey ITB, Piper 285 cams + Vernier pullies with a Megasquirt MS1 V3 and making around 185BHP. It has a Raceline sump and alternator kit. I would have thought the cams are wrecked as the engine is completely out of oil and is seized.
The simple thing to do would be to replace it with another Silvertop as everything will fit. So 2nd Silvertop + new cams = 185BHP.
Or go for a Blacktop + cams to make around 195BHP (blacktop is meant to be 10BHP better than a silvertop)
Or......get a ST170 engine with its stronger bottom end and very good head. With cams around 210BHP ???? Does the VVT operate on aftermarket cams and if so how would you trigger the change over from a Megasquirt.
Ideas or thoughts ?????
RichardK - 25/4/10 at 10:29 AM
I believe that Coozer has this worked out, so maybe worth a quick u2u if he doesn't reply.
Rich
will121 - 25/4/10 at 11:01 AM
dont know how VVT works with performance cams but think shift light output can be used to trigger the VVT as a single action eg on/off but not proportional. think later MS has specific output for it
sebastiaan - 25/4/10 at 11:14 AM
Keep in mind the ST170 engine is a bit higher compared to silver / blacktop zetecs and you might end up with the VVT solenoid sticking through the bonnet.
MS1 extra can control the VVT based on RPM (or any other parameter; I use it on my Indy to transfer from launch control mode to "normal" at 10mph)
MikeRJ - 25/4/10 at 11:34 AM
Only in an on/off mode as will says. The original ST170 system varies the timing continuously.
sebastiaan - 25/4/10 at 11:46 AM
Yes, very true. Don't know if any version of MS does continuously variable cam control, as it would require mac and crank position sensors.
jeffw - 25/4/10 at 12:36 PM
What power difference is there between the Blacktop & ST170?
MikeRJ - 25/4/10 at 01:34 PM
About 40bhp in standard form, the ST170 is around 170bhp.
jeffw - 25/4/10 at 01:41 PM
Pretty sure they would be closer than that with both on cams & Jenveys?
coozer - 25/4/10 at 02:45 PM
Some peeps still don't get it do they??
My VVT comes on after 3K rpm AND above 25% throttle. Thats how I have it set in my MSv2.1.
The timing is varied by the oil pressure and makes no difference in our cars.
With the VVT solenoid 'off' the oil is routed to the front of the cam where there is a helical gear and pushes the cam to full retarted... (emmision control and smooth idle), when the solenoid is given 12v it moves up and transfers the oil behind the helical gear and advances the cam forward, as long as your in the 'on' part of the fuel map it varies by the oil pressure varying.
Totally different to either the rover VVT (electronic) or the SE zetec engine.
Basically the way I have it setup means its in the retarded position when cruising, saving fuel and when I floor it it kicks in and goes ballistic
Go for it, is really that simple, no matter what other peeps will have u think.
