I want to know if the 1.6 Zetec SE Engine (the all aluminium one) has more than one tapped hole in the block, or head, to take a second oil pressure
connection.
I want to fit a VDO sender into one hole and the low oil lpressure light into the possible second one.
There is a second tapping on my Zetec E silvertop engine where I have done this.
The normal way round this requirement is use a t-piece, but there is not much room behind the standard plastic inlet manifold on the SE engine.
The best option is a VDO sender with 2 electrical connections on it. Since I already have a single connection sender I don't want to spend £45 on
another one.
Any help appreciated.
Mal
as far as im aware ive only seen the one in mine, not my my engine case at the moment to look at though
They use a braided hose and mount a t on the end of that.
It protects the senders from vibration and gets round the space restrictions
