I'm at the trying to start stage and all is good except the coil & MJLJ aren't registering anything from the VR sensor.
I adjusted the mounting so it is very close (~0.2mm), square too and in line with the pulley which has increased the voltage to from 0.2V to 0.5V
(measured at the pins of the VR sensor). It isnt close to any other pulleys.
It is a tuned pinto but still running the standard starter motor so is turning over a bit slowly, at a guess ~100rpm, is there a minimum cranking
speed that the VR sensor needs to reach its operational voltage range?
Any thoughts appreciated.
Hugh
Not much help I know but Scudderfish is having EXACTLY the same problems ( see his thread). One of you will be helping the other when you solve it.
I would unplug the megajolt and try to start up just using the edis, it should start ok but will be in limp home mode, maybe swich the wire to the
crank sensor around as the are a specific polarity, check the gap in the toothed wheel is at 90 degrees at tdc, do you have a spark whist cranking?
Couple of things to check fella first.
Rich
Thanks for the replies.
Thanks for the heads up on Scudderfish's thread, there are a couple of things on there I havent tried.
I've tried running in limp home mode (with VR connectors both ways round) and checked the wiring and wasnt getting a spark so assume that
I'm not getting enough voltage from the VR sensor.
The AutosportLabs site suggests it should be reading 2.5v. It doesnt say whether that is the requirement for the MJLJ or the EDIS (or more likely,
both). Also my my A-level physics escapes me, as I cant remember whether the magnet oscilating in the coil (I assume that is how the VR works?)
faster would increase the voltage or the current?
It should run without the megajolt plugged in so it seems to be a problem with the edis or the grounding/shielding of the crank pos sensor (very
important that its shielded) and only grounded at one end too.
Rich
EDIS won't work in limp home if it doesn't think the engine is turning. Right now I've removed my megasquirt and EDIS from the car.
I've directly wired the VR sensor to my multimeter. I've got it up to about 1.3v.
I think cranking speed might have something to do with it as the voltage generated is dependent on how fast the magnetic field is disturbed.
What would be a great help would be is some kind soul with a working set up could measure the AC volts they see on cranking to see if the 2.5V
autosports talk about is obtainable or a typo.
It should but it doesnt... The VR connects to the EDIS and not to the MJ and is needed to run in limp home mode. The 0.5V I've got at the moment
is measured directly off the VR sensor, so it isnt interference giving me a low reading.
The VR sensor cable is shielded and earthed at the EDIS end. The PIP/SAW cable (same
stuff) isnt yet earthed but that's irrelevant at this stage.
Does anyone know what voltage the EDIS requires?
Originally posted by scudderfish
What would be a great help would be is some kind soul with a working set up could measure the AC volts they see on cranking to see if the 2.5V autosports talk about is obtainable or a typo.
Mine does, unplug the MJLT, bridge to get power to the coil (running hard cut limiter pack) and it will start, run, and drive fine. All be it on a fixed advance.
If you tell me which pins you are using I can do the same tomorrow if that would help.
Rich
Sorry for hijacking your thread
I scan read the EDIS patent, but it made no obvious mention of voltages. According to http://www.megamanual.com/ms2/EDIS.htm
In fact, the EDIS module has a built-in VR signal hysteresis - when the VR signal is passing from negative to positive polarity (next tooth is approaching), the signal must reach +0.5 volts before the EDIS module will "arm".
It then will "trigger" when the signal passes through zero on a positive to negative transition, which occurs when the VR sensor tip is aligned with the crank wheel tooth.
The VR sensor drives an input detector which fires on the falling zero crossing of the signal at -300mv.
Rich
Sorry for hijacking your thread![]()
When we check the sensors on truck wheel abs systems we usually get a reading of around 1.5 volts so I.d expect yours to be similar at 300rpm. I will
however try my running v/hall set up either tommorrow or wed to see what cranking voltage i get.
we went to help scoobylav with his avon a couple of years back and he had the ford sensor as well. It was a right bugger to get it sparking. He tried
3 or 4 before he got one to work.
Now we all know it should not be like that surely. Possibly try it with a v/hall sensor or any sensor may do the same job. well on a generic setup it
should.
I had to muck about with resistors in my vr circuit after I got it running as it would not rev above 2500rpm due to the strength/interference of the
vr signal.
Wait, am I missing something? Measuring VR generated voltage with a multimeter? Is that even possible? I always though an oscilloscope was required...
you're dealing with a (near as damn it) sinusoidal voltage...
It wouldn't surprise me if you hooked it up to an oscilloscope and found that you had your 2.5V after all - I'd put my money on it being
another problem. Bad EDIS module? Bad earths? Stretched/damaged wire?
Chris
[Edited on 3/5/2010 by iti_uk]
I dont know, but thought AC current was sinusoidal??
I'm using a fairly standard multimeter in AC mode
The output from a VR sensor certainly isn't sinusoidal
Originally posted by omega 24 v6
I have just been out and measured mines. During cranking I have 1 volt ac measured on a std multimeter that is using the std vauxhall c20xe sensor.
This page sugest it is
Vr sinusoidal wave form
I have a spark
I tweaked the VR sensor again and this time it was actually touching the wheel albeit very lightly. It has taken a minute amount of plastic off the
end of the sensor but nothing to worry about.
I also forked out for a high torque starter as I wasnt convinces the standard pinto starter was man enough for my 2.1 high compression setup, and it
does spin slightly faster now.
The multimeter now reads 0.7V when cranking. Just got the get the carbs and timing right so it runs now...
Good news! I'll have to have a go myself tonight now.
Soz, somethings come up, will try and get it done over the weekend.
Rich
Good news, just read your post, yep mine was touching for a few secs
How thick is your trigger wheel as I've had my doubts about the really
thin ones. Here is mine off a cvh sierra 1.8.
Rich
