As per subject any hard and fast rules using a drill mounted cylinder honer, length of of time to run it in the cylinder etc, thanks guys.
Bob
dont go slowly or stay on the same spot, move quickly up and down the cylinder for a few seconds, job done really.
Cheers spud.
As above but also make sure you apply plenty of lubricant either diesel, paraffin or white spirit.Run the drill at a medium speed and if the pressure
is adjustable use plenty of pressure.
Paul
