this gearbox leak......
FASTdan - 25/5/10 at 11:39 AM
I know I've already posted about this once but i need a guide for dummies lol.
Leak from the bellhousing - I want to fix it in one hit in one weekend, therefore I plan to buy all that is required to ensure I can fix it once I've started.
Can anyone give me a list of things/seals I need - im guessing there's only a couple of possibilities (input shaft seal?).
I've looked in the haynes, but for some reason it doesnt have an exploded view of my gearbox type (N-type), so im just not certain what bits i need.
I've called one transmission specialist who quoted me £40 for full seal set but im sure that must come with 90% of stuff I dont need.
The box came from an 88 2.0 injection sierra.
blakep82 - 25/5/10 at 11:42 AM
if you can wait with the gearbox out, i'm sure any bearing suppliers can give you the seals you need, without selling you a whole kit. that said, if you're doing it, you might as well replace the lot
nick205 - 25/5/10 at 11:45 AM
Likely to be the input shaft seal or the bell housing gasket (if removable bell housing).
I've had advice and parts from this eBay seller a couple of times - he's knowledgable, well priced and very quick on delivery.
http://stores.ebay.co.uk/Transmission-Rebuild-Kits
blakep82 - 25/5/10 at 11:51 AM
he posts on here from time to time too
r1_pete - 25/5/10 at 12:04 PM
Are you sure its gearbox oil, could be the rear crank seal.
Ignore me if this was covered previously....
skinned knuckles - 25/5/10 at 12:10 PM
+1
nick205 - 25/5/10 at 12:36 PM
That may be where I found him originally!
Either way, very good service.
