I have 2 screw in sensors on the block of the pinto are these for oil pressure and oil warning light? Where does the water temp sensor go? I have a
switch that screws into the rad, is this just for the fan switch?
Ive done a search and couldnt find anything of relevance.
temp sender on a pinto is on the front of the cylinder head on the inlet side looks a first glance like a bolt hole.
Yeah got that one, so is the other one the oil pressure? Its bigger and on the same side but lower down and further back. I had them wired up but i
spoke to someone yesterday who didnt think the water temp sender went in the block.
The main reason i wanted to know is i need to know how to wire up the low oil pressure warning light.
