Hi all, I've just got my capri with a 2.0l pinto engine running on honda fireblade carbs and megajolt. The big carbs have had the main jets
drilled to 1.7mm, the needle sliders have been raised slightly and the air correctors have been blocked. The problem is when further up the rev range
4000rpm+ the car feels likes it holding back at full throttle, if you back off the throttle slightly it seems to have more power. Can anyone shed
some light on where I should begin to tweak?
Has this been on a rolling road? Or have you just tried to tune the car in your garage? I think its going to have to go onto a rolling road if you want it sorted out.
I had similar symptoms with my bike carbs - it turned out that my jets were too big, and it was going seriously rich at full throttle.
Other people have had similar results - you really need a RR session or access to a wideband lambda sensor to check.
sounds like its over fueling.
Thanks folks, that was some seriously quick replies
this site is brilliant! Yeah i agree it will need to get a proper rolling road set-up but i
enjoy tinkering away until i get it as close as possible myself....or completely naff it up ha.
I'l try some smaller main jets and see how things go, does anybody know where i can get some jets from?
thanks again
not going to cost anything and from my experience with bikes it might give a result, I would drop them needles back down.
any bike shop should have the main jets, probably about 2 quid each, I amassed heaps of them over the years.
several good online suppliers, will sort out some links later if you need them
The CBR600 carbs on our Zetec were drilled to 1.65mm, I left the needles (after experimenting) and I can't remember blocking the air correctors
(doesn't mean I didn't) and it runs perfectly.
No stumbling or flat spots.
Do you have the Honda workshop manual for the carbs ? If not, it's
HERE
Also, I'm pretty sure Weber jets fit bike carbs, much cheaper too. Have a search (to search this site properly, instead of inserting a space
between the words you're searching for, replace the spaces with percentage signs (%) ).
[Edited on 10/6/10 by UncleFista]
Originally posted by UncleFista
The CBR600 carbs on our Zetec were drilled to 1.65mm, I left the needles (after experimenting) and I can't remember blocking the air correctors (doesn't mean I didn't) and it runs perfectly.
Do you have the Honda workshop manual for the carbs ? If not, it's HERE
Also, I'm pretty sure Weber jets fit bike carbs, much cheaper too. Have a search (to search this site properly, instead of inserting a space between the words you're searching for, replace the spaces with percentage signs (%) ).
I think I'll get two set of 140 jets and then keep drilling one set out until I find a good
setting, then the second set can be used in case I go a step too far quote:
Do you mean you have lifted the main needles ? if so try lowering then and try again
[Edited on 10/6/10 by jacko]
My approach (after reading lots of stuff) was as follows:
1. Balanced the carbs.
2. Adjusted the idle mixture screws, using a AFR meter to check.
1 & 2 were repeated until the carbs were balanced and the mixture was right.
3. Mixture was checked when at wide-open throttle under load (i.e. accelerating hard up an unused road while someone read the display). Adjusted the
jet size until this was OK.
4. Checked the mixture on over-run - not much you can do about that, but it's good to check. Mine was quite lean, but that's OK.
5. Checked the mixture at mid-range revs at steady (light) load - bumbling along the road at 40-ish. This is where you adjust the needles - which I
can't, 'cos they're fixed length - I'm still slightly too rich there.
Originally posted by Capri18
Hi all, I've just got my capri with a 2.0l pinto engine running on honda fireblade carbs and megajolt. The big carbs have had the main jets drilled to 1.7mm, the needle sliders have been raised slightly and the air correctors have been blocked. The problem is when further up the rev range 4000rpm+ the car feels likes it holding back at full throttle, if you back off the throttle slightly it seems to have more power. Can anyone shed some light on where I should begin to tweak?
I think I'll get two set of 140 jets and then keep drilling one set out until I find a good setting, then the second set can be used in case I go a step too farquote:
We run fireblade carbs on a 1.8 Zetec and 150 main jets are about spot on, I would have thought 140s would be too small on your set up
