Hi Guy's
looking for any help on a poor performing Pinto 2L. I have set the timing as per the Haynes manual at 6 deg BTC for un leaded this gave really poor
performance so changed in steps to 10 deg BTC and now slightly better but not brilliant. Tried checking for vacuum leaks by spraying WD40 onto the
hoses and manifold joints to see if i got an increase in revs but nothing. Checked cam is set correctly with crank, checked valve clearence and plug
gaps both OK, fuel mixture seems OK set at 1% on CO2 analyser, plugs look correct colour So any suggestions would be helpful
John
Put a zetec in.
Originally posted by coozer
Put a zetec in.
Has it got an old points based distributor or electronic? If the former, have you double checked the points gap/dwell?
It would help if you said what the actual problem was....
Poor performing how?
Mines set at 12 deg. TDC not BTC. Could that be it?
The main problem is a flat response especially at 4000 rpm +
is it on carbs?
from his archive it looks like he's on a single downdraught carb....
If you are on a single down draught thats your problem. Especially if its a 32/36DGAV.
Some improvement to be had with a 38DGAS if you can find one.
Ignition advance should be set at 8-12 BTDC with standard cam and should be all in, 34-38deg at 3500rpm upwards.
give me £1100 and you can have my pinto, which doesn't perform poorly!
Centrafugal Mechanical advance ?
The advance mechanism might need lubricated and freeded off .
Also have you cleaned the carb jets ?
Originally posted by David Jenkins
I decided to go over to bike carbs when mine started to leak, and I saw the cost of a new replacement DGV.![]()
I can sell you my brand new 500 mile old 32/36 dgav manual choke version
Service kit - yes, they are available. They don't include everything that gets old though. Mine ended up dripping petrol near to the distributor
cap...
Modern replacement? No thanks, I like my bike carbs!
