not getting any oil pressure in my engine.
tried taking the oil pressure doodads out - took the cap off, out comes the spring but if the "plunger" type thing is in there then it isnt
coming out..
any possible solutions?
panic over, got it out..
time to spend some money with SBD
Unless its badly scored sometimes you can get away with giving the valve a good polish with some very fine wet & dry
Always check the valve housing inside the oil pump body though, becuase *if* thats scored your looking at a new pump
thanks perksy,
it is only lightly marked but I never want this to happen while pushing the engine towards 7000rpm so I'm keen to fit the nylon replacement.
I'm going to be ordering mine soon too... Shame its about £50
Anyone got a link to the upgraded relief valve.My 2.0 8v same block as 16v takes a couple of seconds for the oil light to go out would this valve stop this.
here's a link it's in the picture with the oil pump
http://www.sbdev.co.uk/Dry_Sump_Systems/Oil_Pump/Oil_Pump.htm
