If the probe engine is Mazda based will it fit a mx5 gearbox?
Not sure if the probe engine (2l) is mazda based - after all , the V6 in the probe was made in Michigan
And from what I have read on various forum's , the 2 litre is not a great engine.................
I'm not sure, but do remember that the 1.8 V6 out of the mx-3 was meant to be a direct bolt on to the mk1 mx-5 box.
I think the Probe's 2.5 v6 is the same family of engines as the 1.8, so I can't see why not.
I'll ask some of my mates stateside who tune Miatas(mx-5's), they know a hell of alot about them.
have u seen wots in clairetoo car
mazda v6 mated to mx5 ask her
The Mx5 box will go straight on the KL V6 - clutch splines are the same , the release bearing is in the right place - perfect...............except not one bolt lines up , and theres nowhere to put the starter motor !
The 2.5 engine was a mazda engine out of the MX6 and where not a especially good engine and I know parts where extremly expensive (£1800 for a exhaust
so i'm told!
) and the 2.0 didnt have much go in them.
Originally posted by BigFaceDave
The 2.5 engine was a mazda engine out of the MX6 and where not a especially good engine and I know parts where extremly expensive (£1800 for a exhaust so i'm told!) and the 2.0 didnt have much go in them.
isnt the bottom end steel too?
Yep - steel crank and rods
There was a twin turbo race car in Australia with a KL based twin turbo motor - stock crank and block , that made 800 BHP !
I always fancied fitting 1 in a MX-5.
Put that engine in a car it deserves, i think 99% of the bad press is due to the sh!7box Ford it's fitted in.
if i built a MX5 with some go it would have to be a V8, buy the kits from America and it just bolts in
http://www.monstermiata.com/
Um.................I somewhat dispute the claim that they were `not a especially good engine ' !
200 bhp and 8000 rpm for £100 , with a cracking exhaust note , as well as japanese reliability from a quad cam 24 valve V6 that weighs less than a pinto...................
[Edited on 26/6/10 by clairetoo]
Originally posted by bj928
if i built a MX5 with some go it would have to be a V8, buy the kits from America and it just bolts inhttp://www.monstermiata.com/
I was just going on experiences of someone that I work with who had one and was regually going wrong! but im more than
happy to be corrected!
YAWN!!!
Why do so many people go for the "Stick a V8 in it!!" approach.
And then say"Just buy a bolt-in kit", where's the fun in building that?
The whole point of buil;ding a car is to let your imagination run wild and build something you want and is original.
So, if there's a bolt-in kit, it's not that original, is it?
My dad and I, did once measure a friends MX-5 up to see if a V8 would fit, but it was a Bentley Turbo R engine, with aBorg-Warner T56 6-speed Corvette box fitted![]()
So it was a little original, but we could only make it fit, if we band sawed the car down the middle and added at least 3" to the wideth(which we did consider doing!!)![]()
Sorry, spent too long in California, in my early driving year.
It's amazingly common to have a Lil' Monster Miata, or similar conversion kit.
I do like your V10 se7en, I can't wait to see it in the flesh at some point.
I keeop getting tempted by one of claires conversions to drop in Tango then the mrs hears my thoughts and slaps me down again.
One day there will be a sweeeet little mazda V6 mated to an MX5 box in a car I build
Yes, V8 MX5s are ten-a-penny over the pond.
You can fit all sorts in the MX5 chassis, with only *minor* chopping...
http://www.youtube.com/watch?v=jZLnrOeu0KE
So, clairetoo... I hear these Mazda V6 engines are awful boat anchors. Has anyone ever used one in a kit car or an engine swap? Surely, only being
available as a FWD layout, they won't work in a RWD car...
[/AAAARRRRGHHHH!!!!]
Nearly done...
Chris
