How much movement?
DorsetStrider - 29/6/10 at 01:08 PM
Hiya all.
Can I ask how much movement all of you have in your running engines? The reason I ask is that some of the clearances in my build are a little tight and I don't want the engine vibrating against the chassis when I eventually start her up. I'm particularly interested to hear from anyone using an ecotec or redtop engine.
blakep82 - 29/6/10 at 01:12 PM
only had my ecotec running briefly, but virtually no movement. for clearance, i think generally a minimum of 1/2" is ok, but depends on your engine mounts. mine only have a very small bit of rubber in them, so its almost solid mounted
cd.thomson - 29/6/10 at 01:16 PM
I have a redtop mounted on landy rubbers.
No movement.
tomgregory2000 - 29/6/10 at 01:18 PM
i had a lot of movement on my red top when one of the engine mounts broke
loggyboy - 29/6/10 at 01:19 PM
Is the clearance left right or front back?
The red top i had in my tintop moved about 3-4mm left to right on cornering and about 5-10mm front to reving/accel/brake.
When I added reinforced engine mounts (sikaflexed PU in standard mounts) it reduced to half those figures.
Depends on how much play you have in your mounts, and how much power you have to make the engine rock.
DorsetStrider - 29/6/10 at 01:26 PM
The clearances I'm concerned about are left to right (remembering my engine is mounted east west rather than north south). I have roughly 15mm between the fan belt pullys and the chassis and approx 10mm between the gearbox and chassis on the other side.
loggyboy - 29/6/10 at 01:47 PM
Its transversly mounted then?
In which case thats loads.
This is what I had in the Nova (Chassis is modded slightly to give more room):
And some of the same engine in the previous Nova that didnt have the modding so the alt pulley used to catch.
bi22le - 29/6/10 at 05:24 PM
Loggyboy thats a good answer with pics!!
You get a gold star for that effort!
