evening all,
am I right that in thinking that you wind the adjuster in to decrease the fuel pressure.Any pointers greatly received.
Thanks,Sean
Wind it out, I believe - like most regulators.
Where abouts are you, i have a pressure gauge if you want to borrow it.
Shaun
pretty sure DJ is correct. there is a spring loaded diaphragm (try spelling that when yer pissed!) so by turning the screwn clockwise (i.e. doing up)
you compress the spring which applies more pressure to the diaphragm (try spelling that correctly twice when in a hurry).
The net result is that the fuel needs to be at a higher pressure to get past the diaphragm (did I spell it correct that time? stupid word
, must
be French :mad
cheers guys,best unwind that nut then or the bike carbs will be spilling fuel.
