Hi, Can anyone help? I have a 2.0l pinto in my MK, i cannot find any info that relates to my engine being leaded or unleaded. I have looked in the
usual place for the letters stamped adjacent to spark plug 4 but this is either a 1 or an l, not P, PP, R or RR. The only other info i know is that
the engine number means it was build in 1988 and it has a 205 block.
Any advice would be much appreciated.
double check this information is correct
SOHC Pinto Engines
All engines produced after 01/89 are suitable for use with unleaded fuel. For all other engines, an identification mark (adjacent to No 4 spark plug)
must be present to designate suitability for unleaded. These are:
* 1.6 - M, MM or N, NN
* 1.8 - S, SS
* 2.0 - P, PP or R, RR
so from your post I'd assume rightly or wrongly that it isn't an unleaded head.
Hopefully someone more knowledgeable wll be along to clear things up.
[Edited on 9/7/10 by jabbahutt]
My leaded head from an '86 sierra looked like it was stamped 1/l/7 to me, the proper unleaded one I replaced it with was unmistakebly 'R'
SOHC Pinto Engines
All engines produced after 01/89 are suitable for use with unleaded fuel. For all other engines, an identification mark (adjacent to No 4 spark plug) must be present to designate suitability for unleaded. These are:
* 1.8 - S, SS
Thanks for your help guys, think i'll have to run it on unleaded when the time comes and see.
