HI All
Can anyone tell me where I can fit the air flow sensor on the above engine as I am not using the standard air box
As long as you locate it close to the air inlet's, then I'm told (by RAW) that it should be OK. That's what I've just done with
mine and it seems to be working OK.
Good Luck
Rich
Good Luck
Rich
Thanks for the reply Rich will do as you have said
i have the stock tb and no air box. I have little trumpets with air filters. Did not notice it even had an air flow meter! Im running omex if that matters.
