I recently bought a fuel pressure guage to go with my regulator. I have been told that i must set the maximum fuel pressure to 2.3psi, the car is a
ZX9R engined Tiger B6.
I set the pressure to 2.3 psi at idle, is this correct? Just when the car is running and i blip the throttle the pressure guage goes down to zero.
This further shows when driving it because when i go full throttle or over 8k rpm it stutters a lot and wont go any faster.
Am i right to think that the fuel pressure is set too low? And if it is how do i set it properly?
That doesn't sound right! It shouldn't matter what RPM you set the fuel pressure at the regulator should maintain it..... Infact even if you set the regulator with the engine off (but the fuel pump running) it should still work.
Could be the pump isn't able to keep up / restriction in line flowing to regulator etc etc.
Did it start stuttering after the pressure regulator installation?
Work backwards to find the problem.
is it running carbs or injection?
2.3 psi is hardly the pressure you would find in an injection system.
Is your fuel pipe from tank to pump collapsing?
What type of pump are you using?
The bike pump is the easiest option and doesn't require a regulator.
Davie
Davie
The bike pump should work perfectly, I've got mine mounted on the scuttle "sucking" from the tank but it is preferable to have them
mounted at the tank and "pushing".
We used to run a Facet pump and Filter King regulator on a race car and changed to the bike pump after a lot of problems.
Davie
The bike pump should work perfectly, I've got mine mounted on the scuttle "sucking" from the tank but it is preferable to have them mounted at the tank and "pushing".
Davie
It sounds like a flow problem, nothing to do with the pressure. Check the fuel lines are clear and not kinked, is there a blocked filter in the system somewhere?
Pressure regulators that fit into the fuel line between the fuel pump and the carb restrict flow are a liability.
On injection systems it works differently the regulator reduces the pressure by bleeding off fuel from the fuel rail back to the tank.
Better to use a lower pressure pump either a bike pump or Facet road solid state pump (2.5 to 3psi 12 GPH) or an SU style pump with solid state
switching.
