I just offered up the LRS707 starter I bought from ebay, and it looks to me as though the pinion throw isn't long enough to engage with the ring
gear.
I've got a 2l zetec silvertop, with a 1.8 flywheel and a type 9 gearbox. On my car, the distance from the mating face of the starter/bellhousing
to the edge of the flywheel is 35mm, and the ring gear is around 5mm thick, so by my reckoning, the pinion needs to be 40mm from the mating face when
it throws out. Does that make sense? Does anyone have any measurements / starters on the bench they can measure for me / recommendations for another
starter?
Adrian
ive got one and it was working on mine at the weekend. I will take a pic later with some dim's.
Cheers wasa, you're a star!
Thanks wasa, now I'm in trouble! That's the same as the one I have, and it won't reach the ring gear on my flywheel. Has anyone else had this problem?
The pinto one is longer
Don't suppose you have one to hand to measure do you?!
Adrian
nope not played with a pinto for donkeys.
I would double check yours as its the starter every one uses for this set up.
Mines the same as yours, the problem is for some reason my flywheel can't be in the same position as yours, as it's definately 35mm from the mating face to the rear of the flywheel. Don't suppose you know how far from the mating face your flywheel is do you, may help me to start tracking the problem down! Failing that, I may just burn the ba&£@d to the ground!!
sorry I am hopping I dont have to pull it out again
No worries mate
Thanks for the replies
Adrian
