Hey guys, im running a 2.0 Zetec on Weber DCOE 45s. Ive installed megajolt but need a map to put on there!? Anyone got anything similar to my setup and has a map i can copy? Ive tried Autosportlabs website but nothing! Thanks guys
Most people (including me) seem to be using the one on the TigerCat site, but the site seems to have disappeared, taking a small megajolt map library
with it
Here it is in text form;
#Ignition Configuration for MegaJoltLite Jr.
#Sat Nov 20 15:40:16 GMT 2004
userOutType1=1
revLimit=20
userOutType0=1
rpmBins=5,13,15,17,19,21,24,27,30,33
advance9=15,16,18,20,22,24,26,28,30,32
advance8=15,16,18,20,22,24,26,28,30,32
advance7=15,16,18,20,22,24,26,28,30,32
advance6=15,16,18,20,22,24,26,28,30,32
advance5=15,16,18,20,22,24,26,28,30,32
advance4=15,16,18,20,22,24,26,28,30,32
advance3=15,16,18,20,22,24,26,28,30,32
mapBins=20,30,50,60,100,130,150,175,200,220
advance2=15,16,18,20,22,24,26,28,30,32
advance1=15,16,18,20,22,24,26,28,30,32
advance0=15,16,18,20,22,24,26,28,30,32
cylinders=4
userOutMode3=0
userOutMode2=0
userOutMode1=0
userOutMode0=0
shiftLight=18
userOutValue3=14
userOutValue2=13
userOutValue1=12
userOutType3=1
userOutValue0=10
userOutType2=1
I have this one on my 1.8. Works very well.
Linky to autosports
Unc's map looks like a 2d base map set with a 2000 rpm red and the load bins for a turbo, will get you running but only to run the engine in and
drive to a Rolling Road.
A normally aspirated engine will run between vacuum and full atmospheric which according my Ap is 14.7 psi or 101.5 KPI
[Edited on 12/8/10 by snapper]
The load bins are set to 220 KPI max so over half the map will not be seen
thanks guys. I just need something to get me upto rolling road, setup then i can play some more. The rolling road guy aint got a clue with megajolt so
i need to sort it before hand
I have a decent map for that setup, and the rolling road printout with a car running on it. Drop me a U2U.
Dan
i did post up a screenshot on the forum somewhere of an ignition map people could use. at least good enough for a good base map and to get the car
driving.
- colin.
[Edited on 12/8/10 by atspeed racing]
If you take a laptop with Megajolt tune on it, and a disc to upload to there computer, then for the rolling road it should be no different to any the programable ECU
