Yet another auto gearbox problem with my old VR6 engined Galaxy, I don't want to loose it as it is very useful for large stuff
However, it has a good engine and I was just thinking, would it go in the seven, nice narrow 15 degree V, sounds great, 180 bhp, exhaust on the right
injection on the left what do you think
Its a case of what gearbox.
i know its sweet sounding engine in 3rd
got same engine in my corrado
the best thing you can do to those engines is SUPERCHARGE them!!!!
Hell yeh
Yes indeed. The auto could be used but would need the original loom etc as it is electronic
Otherwise the alphax conversion kit for the Audi1.8t to MT75 would probably fit (not certain)
I recon that a bit of work with a grinder, the old VW bell and an MT75 might work
I looked into this about a year ago, to fit a VR6 into a Triumph Herald. I came to the conclusion it wasn't cost effective, compared to other
options.
A VR6, is best suited to either FWD, or Mid-engine use.
get the transaxle from a passat and stick it at the back.... engine at the front.... sorted
never seen that done in a severn, but it might give you better weight distribution!
Originally posted by tegwin
get the transaxle from a passat and stick it at the back.... engine at the front.... sorted![]()
