Does anyone have an edis 4 plug they could sell me?
I have a spare plug.
It's at my folks place tho, if your prepared to wait till im out there in the next week or 2 I'll send it to you for free. Otherwise for a
5er I'll go get it and have it in the post tomorrow?
Forgot to ask where you are!?
Plug is in Ireland
[Edited on 27/8/10 by Craigorypeck]
Hi
I have sent you a U2U with my details.
Regards Lee
Hi Lee. The plugs wrapped and will be sent tomorrow. The pin from number 2 which is not used (think it number 2, its wrapped now cant check) has been moved to the 11pin to be used with the tacho out. All wires are labelled too.
Thanks i will check the pins once recieved
Hi craig
When was the item posted out as i still have not recieved the plug?
Hi plug was posted on Tuesday. Normally takes an extra day to cross the Irish sea but it should've been with you by this stage???
It was sent first class, 31/08.
I have the receipt.
Ah right guess it must have been lost in the post, not to worry these things happen
I'll go down the post office with the receipt and see what they say, I've never had something go missing before.
Hi just to let you know it finally turned up.
