After info on zetec engine ECU's
AdrianH - 2/11/10 at 10:14 PM
I have seen in the past on here a post that seemed to list the various Zetec ECU's and I can remember them having names.
I did a search last night and did not find what I was after. Is there a list of the types of ECU's to be found either 1.8 or 2.0 litre, PATS or None pats.
Lastly I have what is called an EEC IV from a 1.8 CFI Sierra CVH engine, I assume this will be no good to use on the Zetec (Single point injection rather then 4 injectors sequential etc.)
I believe some need external EDis some don't?
Anyway if anyone can point me to a web based list it would be great.
Adrian
Myke 2463 - 2/11/10 at 10:41 PM
big_wasa is the guy with possibly the most info on answering your question.
AdrianH - 2/11/10 at 11:07 PM
I have searched big_wasa's post but not found it, as I though it may be one of his I am thinking of?
Adrian
Myke 2463 - 3/11/10 at 07:18 AM
Escort/Orion 1.8 litre 16 Valve 92-93 92FB12A650CD XEF2FBCD 105BHP
Escort/Orion 1.8 litre 16 Valve 92-93 92FB12A650CE XEF2FBCE 105BHP *NEON*
Escort/Orion 1.8 litre 16 Valve 94 on 94FB12A650BB XEF4FBBB 105BHP *BEAU*
Escort/Orion 1.8 litre 16 Valve 94 on 95FB12A650FA XEF5FBFA 105BHP *BALL*
Escort/Orion 1.8 litre 16 Valve 92-93 92FB12A650BC XEF2FBBC 130BHP
Escort/Orion 1.8 litre 16 Valve 92-93 92FB12A650BD XEF2FBBD 130BHP *COPY*
Escort/Orion 1.8 litre 16 Valve 93-94 92FB12A650BE XEF2FBBE 130BHP *MONK*
Mondeo 1.8 litre 16 Valve 93 on 93BB12A650BB XEF3BBBB *BLOB*
Mondeo 1.8 litre 16 Valve 93 on 93BB12A650BC XEF3BBBC *BLIP*
Fiesta RS1800 16 Valve 92 92FB12A650DC XEF2FBDC 130BHP
Fiesta RS1800 16 Valve 92-93 92FB12A650DD XEF2FBDD 130BHP *ALSO*
[Edited on 6/4/10 by big_wasa]
AdrianH - 3/11/10 at 08:45 AM
Thanks Mike, did not think it was that far back as in April.
Adrian
big_wasa - 3/11/10 at 07:35 PM
Thats only part of the list and it's not complete.
External edis on a zetec is only for automatics.
The zetec has been run on all sorts inclueding a single Dgv weber but the cvh injection would be very much a downgrade.....
From memory didnt the cvh still use a dizy cap on the front of the cam ? Carb version did aswell as an ecu. So wont drive a zetec.
[Edited on 3/11/10 by big_wasa]
AdrianH - 3/11/10 at 07:54 PM
Hello big_wasa, sorry not remebering name.
The carb version was an ESC-Hybrid and a dizy, so yes you are very much correct, that would not run a Zetec but the CFI version I have came with all the loom and ECU, I think it is not a possible unit to use as it only had one injector. Unless that was a 2 Ohm one and the normal ones are typically 12 Ohms then it would never be able to drive 4 individual injectors. The manual still suggests it self learns?
Sorry thats a bit long.
Do you possibly have the complete list or have a pointer to where i could find it, long term project.
big_wasa - 3/11/10 at 08:39 PM
Like I say a full list would be endless.
What info are you actually after ?
AdrianH - 3/11/10 at 09:05 PM
Just which ones to look out for, what age and markings that would be pre pats if possible.
I have a 1.8 Zetec Silvertop from an escort 115 ps version I believe. Came without any ancillaries or even flywheel, just the basic engine. I am planning to add, 1.8 CVH flywheel and crank pulley as I already have these lying around.
Already have edis and coil pack and Megajolt lying around, could go for different carbs. But thought to myself I would like to go injection. Thinking to use a Plenum chamber towards front of car.
I have a bit of a tendency to buy things I think are correct to only find I should have dug a bit more, such as the inlet manifold I bought off ebay was for 1.6 and not 1.8.
My reasoning for pre pats is the wiring I have in the car at present using a Premier loom is all in place so just looking to mod the engine section. Looking for the easiest CVH out and Zetec in I can find. Not looking for very large amounts of power i really doubt i could handle it in such a light car, to get around 140 for me would be the dog's.
I believe I know of someone that may (for a price) wire in Zetec ECU's and would certainly like to not spend several hundred pounds on rolling road set-ups.
Adrian
Also add money is getting short so getting parts over time helps.
Forgot to add have spare CVH starer motor, and spare CVH sump waiting to be chopped. spare pick up etc, basically any bits I need from two CVH engines to help.
[Edited on 3-11-10 by AdrianH]
big_wasa - 3/11/10 at 09:31 PM
Pre pats would be the "blob" ecu after 1994 they are pats so just look for an ecu that comes from a 1.8L manual zetec but make sure you get the keys or the rdif chip is whats needed from the key.
Ford changed the pin numbers and colours between models and even specs hence little info on the net. Diagrams are ecu specific to some extent.
No reason an eec-iv or eec_v wouldnt run from a trigger wheel but you wont be able to adjust the timing so you will need to get it bang on.
Easier to just use a zetec flywheel.
AdrianH - 3/11/10 at 10:44 PM
Found the list I can remember on another site DUH, http://www.ecutesting.com/ford_ecu_list.html
Found a better list
http://faq.ford77.ru/engine/jet/atp_electronic.htm#Ford%20Eng ine%20Management%20ECU
This gives year and engine cc, type!
Looking at the list I could be wrong in assuming the first two numbers of the part number are the year, for example BLOB is
93BB-12A650-BB / BLOB
Would I be correct in thinking that
Scrapped
Mondeo 93BB-12A650-BC / 7145618 / 5029657 / BLIP
Would also be without PATS as all are 93. Would give another option for ECU's to look out for?
Adrian
add a last list for tonight, this list says if PATS is enabled on the ECU
[url=http://www.turbosport.co.uk/showthread.php?144401-ford-ecu-s-and-codes]http://www.turbosport.co.uk/showthread.php?144401-ford-ecu-s-and-codes[/ur l]
Looking for sites that now show wiring?
baz-R - 14/12/10 at 11:31 PM
does this meen my ecu lifted out a fiesta xr2i 1800 (93) 105bhp can be used as it has no imobliser/pats?
its no is 92fb-12a650-cd (2fcd) info says its a ecsort one?
can it just be wired up to get the motor to run?
