Just a quickie guys,before I commit myself to another evil bay purchase,will a rocker cover off a 1.6 165 pinto block fit a 2.0 non 205 pinto block ? Thanking you all again Keith
You'd be better off try to attach it to the cylinder head rather than the block.......
Thank you !(there's always one)
I'd say yes
Took a chance and bought it.Thanks again guys
yes it should fit
There are two different types of rocker cover independent of engine size as they use different rocker gaskets so even if it was a 2 litre it could be the wrong type. Hopefully it will be the correct one for you though.
hi, early ones thin gasket late ones wide gasket.
should be able to fit late cover and gasket to early head but dont think older ones fit newer heads
Ray
