right, sierra LSD back end and I have taken the CV boot off, removed the circlip but the inner lobro joint will not come off the shaft. Do I need a
puller or is something else afoot?
cheers
Craig
there are 2 circlips arn't there, one on the outer side and one under all the grease on the inside?
You only need to remove the outer one to get the joint off.
Sometimes they get a little stuck on the burr around the circlip groove. Normally come off just it a sharp tug, or a tap on the inner with a hammer.
and make sure and put the CV back on the right way round (there is a grove round the outside)
Many thanks folks,
cheers
Craig
I needed a puller on my tripodes.
