ca18det rebuild
graememk - 2/1/11 at 08:48 PM
i bought a running engine from ebay as it had a brand new turbo, i'm not sure how many miles its done but the car was a rear ender and looked tidy.
what should i be changing and upgrading before iinstall itinto the endy and replace the ca18et, i understand these engines can suffer with bottom end probs.
[Edited on 2/1/11 by graememk]
tomgregory2000 - 2/1/11 at 09:22 PM
Big ends death rattle
graememk - 2/1/11 at 09:37 PM
something like this ??
ACL Race con-rod conrod big-end bearings Nissan CA18DET on eBay (end time 15-Jan-11 14:43:17 GMT)
tomgregory2000 - 2/1/11 at 09:50 PM
I would go for oe spec from nissan, everything i have bought for my sr20 i have got from nissan, it tends to be the best quality and about the same cost and it fits, there is nothing worse than getting pattern parts for a couple of quid less and them not fitting propperly, been there too many times
CNHSS1 - 2/1/11 at 10:19 PM
oil pump, bearings (big ends 1st, maybe mains depending on how they look inc thrust faces) and defo clean out all the breather pipes and remove the cam covers and clean out all the sh*te. Even on well known, well looked after engines, they suffer from clogged breatehrs anyway, which depending on who you believe is a major contributor of death rattle. Id also agree that in almost all cases OEM Nissan is better than the aftermarket stuff.
check the bearing shell sizes when you remove them, as nissan has a grading system on top of the sizes. Basically you get (iirc) 5 grades 0-4 of each shell size, std, +25 and +50. Cranks do tend to suffer if the shells arent caught early, and sometimes the thrust faces can be damaged on the crank if its been totally abused.
CAS splines on the exh cams can become worn giving vague timing, but whip it off and have a shufty, not a difficult thing to check.
In my experience of both ETs and DETs, its almost always wee poor maintenance/oil changes from previous owners coupled with sticking a chunk more boost up em that causes issues. Youve defo got the right idea by checking it over before thrahsing the conkers off it
RazMan - 2/1/11 at 10:36 PM
As above really - I had an S13 with this engine in and it was good for 300bhp with just simple mods. Just watch the boost levels and use a progressive controller. They are great engines but do tend to eat big ends.
RK - 3/1/11 at 03:12 AM
Slightly OT, but can you, RazMan, recommend a good boost controller for this engine? It's the one I have.
mggareth - 8/1/11 at 12:34 AM
hi
dont suppose you would be interested in a nice lightend and balanced flywheel
lve got one im trying to sell
gareth
RazMan - 8/1/11 at 12:44 AM
This one is the sort of thing I would recommend - I think it is controlled by rpm and gear too.
http://www.ams1000.com/index.php?option=com_content&view=article&id=62&Itemid=65
