I have put a 2ltr zetec on bike carbs in my sylva star, the car is a q plate 1983 and the old engine was a 1256 viva engine.
I spoke to the mot tester today and he advises it may need a catalyser and an inspection due to the engine change.
I understand that theres been some changed in the testing guidlines recently,
Does a Q plate need emmisions test?
Does it need inspecting by vosa?
Don't they go by the age of the engine as fitted, not the reg year of the vehicle?
Depends. My old Indy was an 1980 reg, but running a 2002 blackbird engine. It was always tested to the 1980 emissions limits. It does seem to vary
depending upon how the car was registered. Some folk have emissions limits on the V5, others are Q plates, and as such should be visible smoke, others
are like mine and done by the age of the reg.
Part of the problem with all the different outcomes is that the system is set up to expect a car of a certain age having an engine of a matching age.
It's when people like us start messing about with stuff that the system doesn't know what to do and as such can generate a few different
answers depending upon who looked at the V5 at engine size/number swap time.
[Edited on 8/1/11 by DIY Si]
He's wrong. No cat should be needed. My car was built with a '91 CVH engine and now has a 2.0 Backtop Zetec. No mention of it at all at
MOT.
Stu
take it to another garage.
I assume that you've declared the engine change to the DVLA? They sometimes ask to have a garage confirm the engine change, but its only for tax purposes, in case your road tax category changes. This won't effect your emissions. Find a more knowledgeable garage.
q plates are visual check only.engine change wont affect it.
Chris
don't think think the DVLA will want an engineers report as you will be giving them more money due to change of tax bracket.
as above it should only be visual on a Q plate.
cars with differant engines fitted are tested to whichever is older for emmisions normally
As said Q plates are smoke test only, if it was not a Q plate I believe it has to pass the emisions at the same level as required for the original engine at IVA, so if upgrading from a pinto to zetec for example emisions should not be a problem at all even without a cat.
Originally posted by deezee
This is easily the most misquoted statement on this forum. Q plates prior to 1998 are visual smoke only. After the SVA was introduced the emissions are set at the time of the SVA / IVA by VOSA, based on the engine and the Q plate is issued by the DVLA. The DVLA do not set your emissions. This information is over 10 years out of date.
