Fuel System Questions
mcg - 19/1/11 at 12:07 PM
Hi - couple of quick questions regarding the fuel lines / system - (sorry if this has been covered b4 - struggling to find it in the search). I am running a vauxhall 8v engine with fire blade carbs. At the moment I have the pump near the tank at the back of the car, then comes fuel filter, then pressure regulator, then carbs. (in engine bay)
1: Do I need a fuel return pipe after the pressure regulator running back to the top of the fule tank? If so, can I move the filter and pressure regulator to the back of the car near the tank and pump, to minimise fuel hose length for the return?
2: Do I need a brether pipe on the top of the tank?
Thanks as always
Matt
blakep82 - 19/1/11 at 12:14 PM
you only really need a return if you're using fuel injection. on carbs, once the regulator is up to pressure, it'll just stop flowing fuel through it.
and yes you need a breather system on the tank, otherwise if you go out for a drive with a full tank, it may look like an accordian when you're done can't remember the exact valve you need, you need one that allows gas both ways, but not liquid
mcg - 19/1/11 at 06:18 PM
Great stuff - thanks for the info.
Does this look like the one??:
http://shop.ebay.co.uk/i.html?_trkparms=65%253A12%257C66%253A2%257C39%253A1%257C72%253A4684&rt=nc&_nkw=fuel+tank+breather+valve&_dmpt=UK_C arsParts_Vehicles_CarParts_SM&_trksid=p3286.c0.m14&_sop=15&_sc=1
errr....sorry for the concise link!!!
