Can anyone recommend a good source for a roller / tensioner kit for an early XE?
Am I just as well going to my local Vauxhall dealer?
Ive heard good things about Autovaux, never used them myself though.
Autovaux or a chap on ebay.
Presume you mean for the timing belt? If so check out your local motor factors for a Gates belt kit, comes complete with everything you need. Would also suggest replacing the water pump whilst doing the job
Would be worth considering going for Steel Idler pulleys (If you don't have them already) and tensioning the belt off the water pump
The plastic pulleys are the work of the devil and have been known to fall to bits
The Steel Idlers are about £35 each from Autovaux
Steel Idlers, Tensioned off the Water pump...
[Edited on 23/1/11 by perksy]
Here here Perksy.
I have binned mine too and they look a lot tidier.
Yes, if you replace the tensioner with a fixed idler pulley the water pump can be rotated in it's housing to tension the belt, which is the
method that several other Vauxhal engines use from the factory.
The big steel tensioner for the early XE is quite expensive (or was when I tried to get one last), though the OEM part was virtually bullet proof.
Mine lasted ~130k in my old Astra, though I did repack it with grease a couple of times.
Cheers Mike!
What Mike says above
Also there is a way of modifying the Steel Tensioner so that it can be used as an Idler (save buying another Steel Idler)
But to be honest if i had the choice, i'd rather just go for 2 'proper' Steel idlers
Vauxhall acknowledged the problem with the Plastic Idlers by reviewing the service schedule on the frequency of changing the Timing belt &
Tensioners (Down to 4 years)
BUT as a Good Insurance policy i'd go for the Steel ones everytime, I know its more money, but the damage that happens when one of the Plastic
ones fail Ain't worth thinking about
I've got myself all confuzzled (it happens easily enough!). So... I need two of these...
... and I don't need one of these because the water pump is being used as the tensioner instead...
I've picked this up wrong... haven't I!?
Can't see the Pictures Mate
I'd recommend getting the Steel Pulleys from Autovaux as they will be the Pukka INA ones
But you need 2 Standard Steel Idler Pulleys
You Don't need the Standard Cam Belt Tensioner as You'll be Tensioning the Belt using the Water pump
Note - One of the New Steel Idler pulleys will be Replacing the Standard fitment Tensioner
Have another look on my photo above and it should be abit clearer
If you get stuck let me know and i'll get the paperwork out from Autovaux for the Part No
[Edited on 24/1/11 by perksy]
Cheers Perksy!
I've changed the pics to links (message below) - hopefully they should work.
It's the early XE engine (round-tooth belt if that makes any difference).
LINK1
LINK2
Correct Mate
Just Don't pay QED Prices
Autovaux will sort you out no problem
Also Don't forget that there is a Steel 'Post' that the Pulley sits on that goes between itself and the Block
Make sure you have 2 and also the Thick Washers that go under the heard of the Caphead screws
(Tighten to the specified Torque with some Threadlock)
If you wanted to be real fussy you could replace the caphead screws aswell
If your missing Any Bits Autovaux will be able to help
Torque Settings are Here:
http://www.sbdev.co.uk/Info_sheets/TORQUE_SETTINGS/2.0L%2016V.pdf
Fab! Thanks again Perksy!
Got mine fro auto vaux too at very resonable prices
